Sponsored by: CARiD
08 range sport supercharge hard starting
Old Feb 13, 2016 | 08:07 PM
Squeaks's Avatar
3rd Gear
Default 08 range sport supercharge hard starting
My 08 is hard starting sometimes throughout the day. Almost like it's not getting fuel but it eventually starts. Any ideas?
Thank you
Old Feb 14, 2016 | 09:35 AM
abran's Avatar
Check the fuel pump relay under the hood in engine compartment.
Switch it with one labeled SM(starter motor).
If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport).
Old Feb 14, 2016 | 02:19 PM
Squeaks's Avatar
3rd Gear
Default Thank you
QUOTE=abran;553764]Check the fuel pump relay under the hood in engine compartment.
If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport).[/QUOTE]
Squeaks
Feb 21, 2016 08:36 PM
GetFrosty
Jul 24, 2012 08:43 AM
nextelsucks
Appearance & Camping Set Ups
May 18, 2008 08:58 PM
nextelsucks
Mar 28, 2008 09:25 PM
