Sponsored by: CARiD
'10 LR4 - Battery Bad?
Old Jun 10, 2016 | 05:27 PM
Herdfan's Avatar
5th Gear
Default '10 LR4 - Battery Bad?
I have a 2010 LR4 with 90K miles. Two years ago I replaced the battery with an Advance Auto Platinum. Everything worked fine until now. At the last service about 4 months ago the dealer told me my battery was going bad and asked if I wanted it replaced. I said no because 1) I still had a year of full replacement warranty from Advance and 2) LR batteries are too expensive for the same battery as you can get anywhere.
So FF to early May. We bought our daughter a car for her 16th birthday and to give her as much experience driving with us as we could, the LR4 sat quite a bit. One day my wife went out to drive it and it wouldn't start. So I put a charger on it and after a few hours it started right up. Similar thing happened a couple of weeks later. So this time I took it to Advance and had them test the battery. They said it was fine. Yesterday it wouldn't start again.
So here is what I know:
1) Dealer says it is going bad.
2) Advance says it is fine.
3) Car won't start.
4) Doors open with keyless entry and radio plays.
5) Battery meters at 12.3V.
Any suggestions?
Thanks.
Old Jun 10, 2016 | 10:28 PM
loanrangie's Avatar
3) Car won't start.
Any suggestions?
Thanks.
12.3V is very low, what does it measure with engine running ?
Should be mid/high 14's at a minimum if not then i'd suspect the alternator to be on its way out.
Old Jun 21, 2016 | 02:54 PM
Herdfan's Avatar
5th Gear
Turns out it was a loose ground connection.
But that doesn't explain why what I did to get it started worked. I finally gave up with chargers and hooked my F-250 SD Diesel up to it with jumper cables. Was getting 13.8V and it took a minute, but then turned over and started right up.
So not sure why it turned over with the additional voltage given that the issue was a ground. But a $62.50 bill from the dealer to fix it is probably the cheapest I have ever gotten out of there so it is all good.
Manito
Mar 28, 2016 06:25 PM
2000_328ci
LR4
Sep 30, 2015 12:57 PM
cabdallas
LR4
May 21, 2015 05:47 AM
JUHSTin
LR4
Mar 5, 2014 05:30 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
