1960 Series 2 Brakes
My master cylinder blew - so I purchased a new one, bench bled it, installed it and power bled the whole system. My pedal goes to the floor first pump but then gives me brakes on the second and third. I am leaking no fluid at all. I have had all the wheels off to clean and inspect the cylinders and the adjusters are up - any ideas why it still seems like air is in the line somewhere? Is it possible to have gotten a faulty master cylinder??
The old CB master cylinders can be a bugger to get all the air out, because of the design. An air pocket stays under the large cap on the end of it. Raising the front of the vehicle so the cap is no longer the highest point can help. The CV cylinders are easier.
Also, it will help if you back off the brake adjusters as far as they go, getting it all bled, then adjusting the brakes when done.
I forgot to mention, it might help to locate the circuit with the actual problem.
Clamp off all three flex lines. Ideally with Girling brake line clamps.
Or you can use needle nose mole grips with small diameter steel pipe or heavy duty rubber hose over the jaws to protect the brake hose.
With all three hoses clamped off, check the pedal. If it's rock hard, then the problem isn't in the MC, if it goes down and all, there's air in it, or in a line before the flex lines (check for leaks).
If the pedal is hard, remove one clamp and try again. Any more pedal travel and you have a bad circuit there. Bleed that one until all the air is out. Reattach the clamp and repeat for the other circuits.
Once you've done that, remove all the clamps, readjust the brakes and check.
timothy_huber
09-15-2014 07:53 PM
collin Barrows
08-02-2011 09:53 PM
purf
07-19-2009 04:47 PM
