2000 disco turns over but won't start
After rebuilding the engine, engine turns over but won't start. I do have spark at the plugs. Is there any way to check the timing without taking the timing chain cover off again. Having some back issues so dragging things apart is not something I am looking forward to again.:(
Seems Rovers are notorious for not starting when the battery terminals are the slightest bit loose. Have you checked those?
nonstart
Originally Posted by OEMPartHaus.com
(Post 551327)
Originally Posted by robersonb
(Post 551337)
Thanks, I will check that. Seems I have plenty of juice but I will check it.
as long as you lined up the two marks your timing should be fine, have you checked for fuel pressure at the rail? or tried resetting the inertia switch?
