Sponsored by: CARiD
2000 disco turns over but won't start
Old Jan 25, 2016 | 05:59 PM
robersonb's Avatar
Default 2000 disco turns over but won't start
After rebuilding the engine, engine turns over but won't start. I do have spark at the plugs. Is there any way to check the timing without taking the timing chain cover off again. Having some back issues so dragging things apart is not something I am looking forward to again.
Old Jan 25, 2016 | 07:06 PM
OEMPartHaus.com's Avatar
Former Sponsor
Seems Rovers are notorious for not starting when the battery terminals are the slightest bit loose. Have you checked those?
Old Jan 25, 2016 | 08:50 PM
robersonb's Avatar
Default nonstart
Thanks, I will check that. Seems I have plenty of juice but I will check it.
Old Jan 25, 2016 | 08:54 PM
Former Sponsor
I just mentioned that because mine was cranking but not starting. Found pos terminal slightly loosened.
Old Jan 26, 2016 | 06:31 AM
drowssap's Avatar
as long as you lined up the two marks your timing should be fine, have you checked for fuel pressure at the rail? or tried resetting the inertia switch?
RuthDeValencia
LR2
Dec 24, 2012 06:00 PM
awillis
Apr 10, 2012 01:53 PM
R4zer
Nov 25, 2010 09:52 AM
golfman
Dec 22, 2006 09:22 PM
