2004 Discovery fuel pump not priming
fuel pump only works and gets voltage while cranking. truck only runs when starter fluid is sprayed in the intake. any clues on why truck is not priming before crank? Fuel pump relay and fuse works fine. Any help will be appreciated. Also, its a new pump.
It doesn't even start warm. Why would I not be getting voltage to the pump before cranking at least 2 seconds? That's going to be my reason for not starting right up.
