Sponsored by: CARiD
5.0 Do not rotate engine backwards
Old Sep 17, 2018 | 03:25 PM
Phydeaux1's Avatar
4wd High
Default 5.0 Do not rotate engine backwards
In reading the shop manual regarding the Range Rover 5.0 (NA) it states not to rotate the engine backwards, but does not explain why. Never seen that regarding any engine. Can anyone explain what happens if the engine is rotated backwards?
Old Sep 18, 2018 | 12:45 PM
mollusc's Avatar
I've seen that in every workshop manual I've ever read. Not certain of the reason for it though.
Old Sep 18, 2018 | 01:22 PM
OverRover's Avatar
For one thing I would think rotating the engine anticlockwise could cause issues with the timing chain tensioners and guide blades.
Old Sep 18, 2018 | 05:13 PM
Phydeaux1's Avatar
4wd High
I thought for some reason it may also have something to do with the mechanically driven two high pressure fuel pumps on the side of the block.
Birdperson
Sep 4, 2017 12:44 AM
G150driver
Mar 23, 2015 10:01 AM
TRIARII
Jan 27, 2014 01:38 PM
DiscoDad
Dec 24, 2010 08:26 PM
jrmnw1
Dec 4, 2009 10:12 AM
