Sponsored by: CARiD
95' classic range rover brake problem
Old Feb 13, 2007 | 06:48 PM
dumellarah's Avatar
5th Gear
Default 95' classic range rover brake problem
I have a 95 classic range rover andhave just had the brake light warning come oninthe dash console and then the brake pressure reduced by about 50% of normal. Would some know what might cause this problem.
Old Feb 13, 2007 | 07:02 PM
geoman's Avatar
Default RE: 95' classic range rover brake problem
First-- open the hood and check the fluid level. Second-- do you hear a whining noise coming from under the steering column/pedal area when you first start the vehicle? You should--- but only for about 10-15 seconds while the ABS system is pumping up pressure. If you do not ---or the pumping noise just continues on and on --then you have a ABS accumulator and/or Modulator that has failed.
Don't drive it without checking this out!!!!. You will be amazed at how poorly a vehicle this heavy will stop without the system assist.
regards,
Geoman
www.eurotekapg.com
Old Feb 15, 2007 | 02:30 AM
dumellarah's Avatar
5th Gear
Geoman,
Thank you for your reply, I started the vehicle and there was no noise in the location that you described. There was however a definite noise of some sort of pump that ran for about the approx time described and then released a short hiss of air once it stopped running but it has always made this noise. Could there be an electrical fault with a relay and if so where would the relay be locate to check this?
Regards,
Dumellarah.
Old Feb 15, 2007 | 06:19 PM
geoman's Avatar
That "hiss" sound is your Air suspension pump. The sound I was asking you tolisten for relates to the ABS pump. The fuse # in the main fuse blockthat serves the ABS pump is "30".There is also a relay, and a diode that sometimes fails. I believe the relay is in the engine compartment, but I don't recall where. The ABS electronic control unit is located under the drivers seat.Check the fuse first --- then check the connectors at the ABS ECU.
Geoman
Old Feb 16, 2007 | 12:20 AM
dumellarah's Avatar
5th Gear
Geoman,
Again thank you for your reply, I checked the fuse bank at the rear under the drivers seatand all seems fineand the 30 amp fuse in the engine compartment, however i cant check the relays so i have arranged for an auto electrican to look at it from here. I would assume that if there is no power to theABS pressure pump that it should be a diode or a relay as you say and not the pump motor or accumulator themselves? There are three relays located on the right side under the drivers, can you tell me if these are for the ABS?
badfysh
Oct 23, 2012 10:45 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
range95
Jul 8, 2011 08:29 AM
Arsene
May 27, 2010 06:22 AM
Classic89
Feb 18, 2008 04:31 PM
