Bad Brake Master Cylinder?
When I press the brake pedal on my 99 DiscoI it goes nearly to the floor. One pump of the pedal firms them up for good stopping. The rotors and pads are fairly new, and the brake fluid is full. My mechanic say's the "one pump" symptom most probably means I have a bad Master Cylinder. Does this sound right? If so, can a novice mechaniclike me replace/rebuild the master cylinder? Where can I find a rebuilt master cylinder? I see Atlantic British has a new master cylinder for $190. Any other good sources?
RE: Bad Brake Master Cylinder?
Disco 1 uses the same hubs as the Defender - could be the bearings need adjusting. If they're too loose the pistons in the caliper get pushed back more than normal due to the extra movement in the hub - thus, first press of the pedal and it'll go a lot lower than normal, second press and the pistons have moved back out and normal braking is restored. Over the course of a few miles and they'll get moved back in again and the process is repeated.
If it's air or water in the brakes, releasing the pedal and repressing it after a few seconds, with the engine running, whether the car is in motion or not and you'll get the same symptom of the pedal going lower than normal. If it's the hubs, with the engine running but the car stationary and the pedal will be normal until you drive off.
Hope that helps,
Hope that helps,
You will not normally see the brake fluid leaking out externally of the brake master cylinder or from the wheel areas when this pedal softness occurs, so fluid level alone isn't an indication of a good or bad brake master cylinder. The fluid will usually not be low or in need of topping off…remember the leak is internal and the brake fluid is leaking past internal O-rings, so an obvious external sign that the master cylinder is "bad" is usually not existent.
Adz - Is adjusting the bearings an esay task? One that can be done in the driveway? I think this may be the cause of a steering wheel shake when I brake. I've changed everything there is to change but have the same problem. Also my front left pads wear quicker than the other side.
