Sponsored by: CARiD
battery earth lead
Old May 7, 2009 | 12:19 AM
matthew527's Avatar
5th Gear
Default battery earth lead
If "battery earth lead" is the negetive lead why will the repair manual say disconnect "battery earth lead" rather then saying disconnect "negative lead". are there any ideas?
Old May 7, 2009 | 06:37 AM
wilson96rr's Avatar
For the same reason the message center says "bonnet open" and not "hood open." Different places use different terminology for the same things.
Old May 7, 2009 | 07:07 AM
antichrist's Avatar
If you say "earth" (or ground) lead, then whether it's pos of neg earth(ground), you're disconnecting the correct lead. Land Rovers were positive earth until the early 60's.
You always disconnect the ground, not the "live" lead.
Old May 8, 2009 | 02:11 AM
KarenCaren's Avatar
That is just the term use by landrover manuals. That is like a more mechanic type of term not for a simple mechanic but you can still get the idea.
_____________
If you ain't first your last!
jetta parts
Dono
Aug 7, 2013 08:22 PM
robersonb
Nov 9, 2012 11:06 AM
antichrist
Mar 29, 2011 08:41 PM
WOZ
May 24, 2007 02:36 AM
