blinking check engine light -intermitant rough run
I have a 2003 disco11 60,000k the truck has a intermitant rough engine and when this happens the check service light blinks
Has it ever been tuned, what octane gas are you running? Go get your codes read and get back to me with the 4 digit fault code numbers so we can have a better idea what is going on.
2003 disco11 codes read ref
Thanks Mike got the codes- P0441 egr /evap control sys purge fault and P0306 #6 misfiring
last service 50k by land rover ,running mid grade gas-my wife put reg in it once
again ,Thanks mike |
The evap code will not effect the way the engine runs, the #6 misfire is common and will cause you problems.
You need to buy some good plugs, either Champion dual platinum of Bosch Platinum Plus 4's and do that as well as the 60K service and tell your wife, she will be riding her bike if she doesn't run high test only, there is no room for debate on that one. Look at my service list posted on the Discovery section, all that needs to be done. How mechanical are you? |
30 year police captain at night 20yr carpenter by day try to do most car work myself
the plug wires look good no easy by looks to change wha do u think
Mike do you have to gap the bosch +4 plugs ands i can not find your service list .First time user of this site
Thanks in advance Dave |
Mike found your excellant service list
Thanks dave |
problems resolved
A big thank you to Discomike had the wires changed and new spark pl;ugs done-runs great-will have all otherr 60k items done
| All times are GMT -5. The time now is 05:44 AM. |
