Sponsored by: CARiD
Change Spark Plug Wires 99 Disco 2
Old Mar 7, 2006 | 12:05 AM
mikedemet's Avatar
Default Change Spark Plug Wires 99 Disco 2
I would like to change my spark plug wires myself, but the distributor is located behind the engine. Has anyone done this? I would love directions. My Cyl 4 wire is arcing and I would like to do it this weekend. Please help. Thank you in advance.
Old Mar 7, 2006 | 11:24 PM
Bait's Avatar
Default RE: Change Spark Plug Wires 99 Disco 2
No distributor. Coil pack. Need to remove the upper intake plenum to change. Not for the faint of heart. Very doable if you are mechanically inclined.
Old Mar 8, 2006 | 01:17 AM
mikedemet's Avatar
Thanks dude, the dealer quoted my $952.00 to replace, I nearly keeled over. This after $110.00 to diagnose. (The tech sprayed the wires with a garden hose).
Old Mar 15, 2006 | 05:13 PM
2000discoII's Avatar
WOW, $952.00. I thought the dealer I called was crazy, $700.00, but they won't install the Magnecors I bought, only OEM. I think I'll be doing it myself.
Old Mar 15, 2006 | 06:51 PM
mikedemet's Avatar
Be careful removing the intake manifold. I am getting written instructions and I will post them when I do. Also you should get a replacement gasket for the upper air intake manifold right away...about $40.00. I am also replacing my ignition coil pack with one I bought on EBAY. I still cant believe the morons buried this stuff behind the engine, under the manifold.
The dealer would hit you with all this stuff anyway, and he would get about $2,000 for it.
Old Mar 15, 2006 | 10:39 PM
Bait's Avatar
Just out of curiosity, why are you replacing your spark plug wires. Check engine light / arcing ?
Old Mar 15, 2006 | 11:25 PM
mikedemet's Avatar
Here were the symptoms. Check engine light blinking. Multiple misfire. Cyl 4, 7 misfire. Loss of horsepower, rough engine running. I took it to the dealer and they hosed me for $110.00 to literally hose my wires. They said that one of my wires was arcing and wanted $952.00 to replace all 8. I decided to get it out of the dealer immediately. I checked online and realized that the 4 and 7 leads are right next to each other on the same coil pack. Intuitively, the coil pack is shot. This is a $700.00 part at the dealer. So they were going to nail me for another $700.00 + install for the coilpack as soon as they got the intake manifold off and I was trapped. So I went to EBAY and bought a used but tested coil pack for $100.00 + $15.00 Shipping. On another website I purchased new plug wires and a upper intake manifold gasket for about $95.00 including shipping. Now I have to figure out how to pull it all apart and snap it all together. It is not brain surgery, so I want to do it myself. With the $1,500.00 I save I will take the family to Florida in the Landy.
Old Mar 18, 2006 | 12:33 AM
Drnknmnky13's Avatar
ORIGINAL: mikedemet
That should just about cover the gas at todays prices
Old Mar 18, 2006 | 11:26 AM
Landzu's Avatar
Boy I'm happy I have a DI, I had no idea that the
DII's set up was like that.
I would put wire wrap on the plug wires they may
last longer.
Good luck.
Old Mar 19, 2006 | 04:55 PM
dchyun's Avatar
8th Gear
I just did mine yesterday. I got champion 3322 plug (OEM) from Napa. 2.50 each.
Easy job!
I can't believe dealer charge that much for simple, 30 min. to an hour do it yourself job.
