CHECK ENGINE LIGHT ON
WELL THIS MORNING I WOKE UP STARTED UP MY DISCO WITH MY REMOTE START AND WENT OUT TO GET IN THE DISCO AND SERVICE ENGINE LIGHT WAS ON.
WENT TO AUTOZONE THEY READ THE CODES BUT DID NOT CLEAR THEM. I DIDNT ASK TO CLEAR THEM.
CODES ARE:
P 0301 - PRINT OUT SAYS: CYLINDER MISFIRE DETECTED-CYLINDER NUMBER 1 PCM HAS DETERMINED THAT A MISFIRE OCCURED IN CYL. NUM. 1.
P 1590 - NEUTRAL POSITION SWITCH CIRCUIT HIGH INPUT
P 1668 - PCM - IDM COMMUNICATIONS ERROR
SO IM HOPING I NEED NEW WIRES AND PLUGS ONLY. THE DISCO HAS 79,000 MILES AND I HAVE NEVER REPLACED THE WIRES OR PLUGS. I'VE HAD IT SINCE JUNE OF 2006 WITH 49,000 MILES ON IT.
IF ANYONE HAS ANY INFO OR SUGGESTIONS
DISCO MIKE. LOL IT WOULD BE GREATLY APPRECIATED.
CODES ARE:
