Codigo error land rover Discovery 1 v8i
Hola amigos, me presento por acá. Mi nombre es Andrew y soy dueño de un Discovery 1995 v8i 3.9lt.
Mi camion tiene encendida la luz de check engine y logré visjalizar debajo del asiento del pasajero el codigo en la pantalla. Me señala codigo error 12 y queria si me pueden ayudar con los codigos OBD1 de este Land Rover y que significan y como resetearlos despues de reparar.
Un cordial Saludo.
Un cordial Saludo.
Google translate's version:
Hello friends, I'm showing up here. My name is Andrew and I own a Discovery 1995 v8i 3.9lt. My truck has the check engine light on and I managed to see under the passenger seat the code on the screen. He points me out code error 12 and I wanted if you can help me with the OBD1 codes of this Land Rover and what they mean and how to reset them after repairing. Best regards.
Put the ignition switch in position II.
Disconnect the Data Link Connector (DLC) , which is located behind R/H side of dash, and wait 5 seconds. Reconnect data link connector.
Put the ignition switch in position 0 and wait till the load relay drops out.
Put the ignition switch in position II. The display will be blank if no other faults exist. If other codes exist, the next fault code will be displayed.
If multiple faults exist, repeat steps 1 through 4 until all faults are cleared. NOTE : Code 02 indicates that the Engine Control Module (ECM) has just been reconnected. Switch the ignition switch to position II to clear code 02.
Code
Circuit Or Condition
02
Battery Recently Disconnected
03
ECM Memory Recently Cleared
MAF Sensor
14
ECT Sensor
15
Engine Fuel Temperature Sensor
17
Throttle Position Sensor
18
Throttle Position Sensor/Mass Air Flow Sensor
19
21
Fuel Tune Select Resistor
23
Fuel Supply
25
Ignition Misfire
28
Air Leak
29
ECM Memory Check
34
Injector Bank A
36
Injector Bank B
40
Misfire Left Bank
44
HO2S Left Bank
45
HO2S Right Bank
48
Idle Air Control Valve
50
Misfire Right Bank
59
Group Faults 23/28
68
Vehicle Speed Sensor
69
Park/Neutral Position Switch
Code
02
03
MAF Sensor
14
ECT Sensor
15
17
18
19
21
23
Fuel Supply
25
Ignition Misfire
28
Air Leak
29
ECM Memory Check
34
Injector Bank A
36
Injector Bank B
40
Misfire Left Bank
44
HO2S Left Bank
45
HO2S Right Bank
48
50
Misfire Right Bank
59
Group Faults 23/28
68
69
sloan74
Aug 19, 2010 11:46 AM
Kumba830
Oct 29, 2008 06:48 PM
