Compounding Problems
Old 08-22-2008, 08:00 PM
Disco C's Avatar
Default Compounding Problems
2003 Disco 68000 miles. Last week I pulled 2 codes P0130 and P0171. Cleared themselves a few days later. One week Later CEL came back on pulled P0130 and P1171. Purchased truck 1 year ago with 62000 miles. Did the 60000 service at that time. Including serp belt, plugs and wires. One month ago engine had a tick, CEL light(P0130 and P0171). Had 2 front O2 sensors changed, engine flushed, switched to Mobile1 syn and K&N Filter. Slight tick still there. Also have some leaking(rain water). Front Drivers side A pillar and drivers side Alpine window. Been a tuff week for me and my Disco. Any help, advise, thoughts or prayers would be apprciated!
Old 08-22-2008, 08:36 PM
WolfPack's Avatar
Default RE: Compounding Problems
Any oil pressure problems?
Old 08-22-2008, 09:18 PM
You are running lean, may have a MAF failing. Does your exhaust stink, how is the tranny shifting into 4th?
Old 08-22-2008, 09:47 PM
Disco C's Avatar
Well it is a 2003 so oil presure is always a major concern. The first time I noticed the tick I had the oil presure tested, no problems. Oil pan dropped to clean out oit pick up tube, not clogged. I have not noticed any smell from exhust or problems shifting. thaks for any advise or ideas. Thought maybe I should also change out the back 2 O2 sensors even though CEL indicates front!
Old 08-23-2008, 07:28 AM
Landzu's Avatar
ORIGINAL: Disco C
K&N Filter.
MAF ,,,,, mass air flow sensor.
Old 08-23-2008, 12:34 PM
Disco C's Avatar
K&N oil filter 3001, OEM air filter. Sorry for the confusion. Do you think the best action to take is changing the MAF, as well as the back O2 sensors?
Old 08-23-2008, 01:07 PM
Disco C's Avatar
Just a thought. Since im showing codes for front sensors (even after replacing front O2's) and have the tick noise whenengine warms up. Maybe an exhust leak? Intake manifold?
Old 08-27-2008, 06:46 PM
Disco C's Avatar
So I decieded to clear the codes to see what would come back before purchasing any parts. P0130 is the only code that came back. Odd since the 2 front O2 sensors are new. Im stumped!
Old 08-28-2008, 06:11 PM
Disco C's Avatar
Still stumped. Now Im talking to myself! Guess I need a mechanic to check it out (For the truck, a doctor for me).
Old 08-28-2008, 09:16 PM
roverguy7's Avatar
do you hear the noise from the drivers or pass side of the car, an exhaust leak can easily set a lean code, and a o2 sensor code
Quick Reply: Compounding Problems
