crank position sensor
'88 RR. No spark.
RE: crank position sensor
Where do I find it?
How do I test it?
you dont have one. whats wrong with the car... aside from the assumed no start that you have
No spark from coil. Coil and relays test ok.
from coil to distributor, or at the spark plugs?
from the coil
you most likely need a new ignition module, could just be a coil though... ign module should be seperate on that year, but i believe the only way you can get it now is with a distributor, so youll need one of those,and a new coil
Is there any way to confirm that? How would I test the ignition module?
Thanks for your responses. Ok, just to clarify. Starter spins. When I pull the coil wire off at the distributor and crank the starter, I get no spark (grounding the coil wire out, of course). I pulled the coil and had it tested by my parts guys. It's supposed to be fine. From that, I have to assume the fault lies before the coil. Any suggestions? Could that still be the ignition module.
