Sponsored by: CARiD
crank position sensor
Old Aug 4, 2008 | 01:15 PM
wosmo's Avatar
Default crank position sensor
'88 RR. No spark.
Old Aug 4, 2008 | 01:17 PM
wosmo's Avatar
Default RE: crank position sensor
Where do I find it?
Old Aug 4, 2008 | 01:19 PM
wosmo's Avatar
How do I test it?
Old Aug 4, 2008 | 09:47 PM
roverguy7's Avatar
you dont have one. whats wrong with the car... aside from the assumed no start that you have
Old Aug 5, 2008 | 09:35 AM
wosmo's Avatar
No spark from coil. Coil and relays test ok.
Old Aug 5, 2008 | 10:45 PM
roverguy7's Avatar
from coil to distributor, or at the spark plugs?
Old Aug 6, 2008 | 09:56 AM
wosmo's Avatar
from the coil
Old Aug 6, 2008 | 11:22 PM
roverguy7's Avatar
you most likely need a new ignition module, could just be a coil though... ign module should be seperate on that year, but i believe the only way you can get it now is with a distributor, so youll need one of those,and a new coil
Old Aug 7, 2008 | 09:50 AM
wosmo's Avatar
Is there any way to confirm that? How would I test the ignition module?
Old Aug 7, 2008 | 09:55 AM
wosmo's Avatar
Thanks for your responses. Ok, just to clarify. Starter spins. When I pull the coil wire off at the distributor and crank the starter, I get no spark (grounding the coil wire out, of course). I pulled the coil and had it tested by my parts guys. It's supposed to be fine. From that, I have to assume the fault lies before the coil. Any suggestions? Could that still be the ignition module.
