Sponsored by: CARiD
disco 11 doors won't lock
Old Nov 10, 2005 | 07:30 PM
area4us's Avatar
8th Gear
Default disco 11 doors won't lock
Hi , just bought my first rover 01 disco 11. My door locks won't stay locked, they just pop right back up. My guess is the inertia switch. can someone help
Old Nov 10, 2005 | 08:48 PM
area4us's Avatar
8th Gear
Default RE: disco 11 doors won't lock
please help wife wan'ts to bring it to the shop, but I think I can stall her and order a new switch on ebay if someone can confirm solution.
Old Nov 10, 2005 | 10:14 PM
mikemeyer0's Avatar
You can't lock the doors manually when any door is open. You have to use the remote. If the doors are closed you can lock them manually. I do not think its the intera switch at all. Do they lock w/ the remote?
Old Nov 10, 2005 | 10:49 PM
area4us's Avatar
8th Gear
hi thanks for responding,
The doors lock with remote and manualy, but imediatley unlock. I have tried everything including reseting switch which was in up position. After I reset switch I was getting a beep when I activated remote lock, that I wasn't getting before I reset inertia switch. I than unplugged switch and still got the same results which is leading me to believe that the switch is junk.
Old Nov 11, 2005 | 10:30 PM
area4us's Avatar
8th Gear
can anybody help? please
Old Nov 11, 2005 | 11:25 PM
Bait's Avatar
Does the car run ? If so, not the switch. When locking the horn blows once ? Do all door sill buttons go down ? then up ?
Old Nov 12, 2005 | 10:32 PM
area4us's Avatar
8th Gear
yes,the buttuns fgo down then up whether you use the remote or the switch on dash.
Old Nov 14, 2005 | 01:32 AM
Bait's Avatar
Hmm... Never seen that on a D2. If all doors ( 5 ) are closed it should not beep and unlock. It is thinking there is an open door. Could be a bad latch or wiring issue.
A good introduction to British electronics for ya
Old Nov 16, 2005 | 07:02 PM
area4us's Avatar
8th Gear
The locks worked fine, until I activated the child safety latch on the rear pasenger side door. Im thinking that may of somehow created the problem.
Atwine
Nov 20, 2014 05:25 AM
wynhd
Aug 28, 2012 11:33 PM
buick215
Jul 22, 2012 12:31 AM
coloradorover
Mar 3, 2011 05:15 PM
russcan
Sep 14, 2008 10:45 AM
