Disco 2 Traction Control
Hi guys,
I just recently bought a Disco 2 and the guy i bought it from had said that the traction control has been deactivated, The ABS works fine but the HDC does not seems to be working, (When i press the button there is no notification lights on dash)
Can someone help me where to start to try figure out if it works and if not how to get it working. Im sure he said that the unit had gone on it and a new one and that the remapping was very pricey.
Please Help
Please Help
Just following up on Dro's suggestion, the traction control basically uses the abs to stop wheel spin and send power to the side that has traction in the diff. Dro is the expert here and is suggesting that a relay could be the issue because you said the abs is working. Normally, people get the three amigos (abs, traction control, and hill descent) because the abs system is reading a fault. Abs faults are common and affect all three systems. Since the traction control and hill descent are out... I hope you just need a relay but if it isn't that I would be curious whether you really do have abs working. I read a thread a few months ago about a guy who took his truck to well known indie shop for abs problems and he later learned that the jackass mechanic just disconnected the abs light! I only mention that since the truck is new to you.
If you off road, or drive through seriously deep snow, it makes a world of difference.
I retrofitted a Discovery I transfer shift linkage into mine about a year after I bought my '99, and wish I'd done it sooner. Next up is the SLABS module from a 2004, so I can start the truck with the diff locked and not have to deal with the 3 Amigos.
I have the same setup and I just keep a 10mm wrench with me... And some throw away towels... In case I need to engage it.
