Disco 2 won’t start
Ok, I’m really embarrassed to have to ask this. But here’s what happened. I was distracted and parked the disco and couldn’t remove the key. So when I returned an hour later, it wouldn’t start. The next day, I tried again and figured out I left it in drive 😳. Im used to driving a manual.
so I charged the battery, and it still won’t start. It acts like it’s not getting fuel or spark. It turns over strong though.
so might I have damaged the ignition barrel? What else should I investigate?
Thanks so much in advance.
—cheers, Chris
—cheers, Chris
eliminate a flash fitting wire from any flash attachment and I would go for chamber #2. This is the simpler flash fitting wire to access for evacuation. Second, disengage the wire from the flash fitting and have a companion attempt to turn over the motor. You ought to hear a starting sound and once in a while can see the flash from the free wire. In the event that you have flash, your wrench sensor is great. On the off chance that flash is absent, I'm willing to wager your wrench sensor is to be faulted. This is some development car analysis and ought to be perform by somebody with specialized abilities and gear u can use my favourite apps like snaptube and vidmate
DiscoUSA
04-24-2017 10:28 PM
bn_bnntt
06-26-2011 06:31 PM
