Engine Dies
I have not had time to check much. Iwas lookong for fuel the filter. I do not have a book yet, but what I though was it is in frount of the tank on the frame rail right side. But I went to NAPA and the filter they showed did not look anything like what I was looking at. I was told today it may bet behine the letf frount wheel. I'll look to night. Also told it may be crank sensor.
I knew it would be a dumb question when I got the answer. Thank you. I'm not getting many oil around them but I'll checkthe back.
There is some oilon the lower part of the engine. And no spark when motor dies,when it cools it starts, also there is dirt and oil around the crank sensor I'm going to clean it as much as I can andsee if that helps. Plus go but a code reader! I see I'll need it wiht LR's.
on
How long have you had this, when do you plan to go thru and real service and tune this truck, your truck, by mileage is past do for 4 02 sensors, although you haven't caused this particular problem.
What are the exact fault codes that took you weeks to find?
Is there oil leaking from the drivers v/c gasket, UPS, already asked that and didn't get a reply.
When you get around to checking and getting me the information I asked for, I'll tell you what is most likely wrong with your truck.
