Front O2 sensor replacment
The harness melted and i don't know what wires to match up to my 4 wire ( Black, grey, and 2 white) O2 sensor.
I looked in the rave manual but could not find it in the electrical library or electrical circuit diagram. where in rave manual is could i find this? the O2 sensor is new, and the harness is now melted! I took the harness apart and it just cracked I hooked it up Black to Blue with peach stripe gray to Black with yellow white to yellow with green stripe white to blue with yellow stripe Its not running right and is having code, the white could be switched and i would have know so i'm going to switch them. |
Is this a universal O2 sensor with no plug?
If so it should have instructions with it right? I dont know the answer just throwing things out there. |
O2
Yes it A universal O2!
i installed it and it really helped for about 1000mi. Then the harness melted. I looked at the harness and spliced the wires together how the looked like they should go. It ran horrible. since my last post i have taken it out and put some no lock on it and cranked it in. I switched the to white wires. It seems to be running better but I'm not sure it started to shake and the check engine light started blinking so i took it home quickly! going to switch the white wires tomorrow. any one had directions? any one know where in the rave manual i could find the information? |
O2 sensor in front of engine
universal 4 wire o2 sensor. Harness melted need to splice wires |
Both banks? Check the other side!
