Sponsored by: CARiD
Front O2 sensor replacment
Old Nov 25, 2010 | 01:13 PM
Marcoadieter's Avatar
Default Front O2 sensor replacment
The harness melted and i don't know what wires to match up to my 4 wire ( Black, grey, and 2 white) O2 sensor.
I looked in the rave manual but could not find it in the electrical library or electrical circuit diagram.
where in rave manual is could i find this?
the O2 sensor is new, and the harness is now melted! I took the harness apart and it just cracked
I hooked it up
Black to Blue with peach stripe
gray to Black with yellow
white to yellow with green stripe
white to blue with yellow stripe
Its not running right and is having code, the white could be switched and i would have know so i'm going to switch them.
Old Nov 26, 2010 | 07:31 PM
Is this a universal O2 sensor with no plug?
If so it should have instructions with it right?
I dont know the answer just throwing things out there.
Old Nov 27, 2010 | 06:14 PM
Default O2
Yes it A universal O2!
i installed it and it really helped for about 1000mi. Then the harness melted.
I looked at the harness and spliced the wires together how the looked like they should go. It ran horrible.
since my last post i have taken it out and put some no lock on it and cranked it in. I switched the to white wires.
It seems to be running better but I'm not sure it started to shake and the check engine light started blinking so i took it home quickly!
going to switch the white wires tomorrow.
any one had directions?
any one know where in the rave manual i could find the information?
Old Dec 5, 2010 | 08:41 PM
O2 sensor in front of engine
universal 4 wire o2 sensor. Harness melted need to splice wires
Old Dec 6, 2010 | 09:24 AM
Disco C's Avatar
Both banks? Check the other side!
tblanch258
LR2
Dec 12, 2013 04:56 PM
kman35ca
Apr 16, 2012 10:12 AM
MLandry7
Dec 3, 2008 09:38 AM
Chillbilly
Jun 4, 2008 03:51 PM
cpl55
Apr 20, 2007 01:06 PM
