Fuel pump?
Fuel pump?
Please help with my 03 Disco II with only 40,000 mi. Stopped at the pumps and filled up then would not start. Pushed it out of the way, waited 30 min. and it started, got it home about 10 min. away and it died. Now when it is cool it will start and run for 10 min. or so then dies. wont start again till it cools. I can do this all day. Thanks.
Thanks, Disco Mike. Let me tell you what I have found so far. I have accessed the fuel pump through the cargo access panel, disconnected the fuel line, turned key and it pumped fuel, reconnected and it started ran for 10 min. and stalled, disconnected again, turned key and no fuel would pump. till it cooled off again in about 30 min. No service engine light, throwing no codes. where can I find the crank sensor. thanks, Disco Chelsea.
The crankshaft sensor is on the left (driver's side in the US) side of the engine at the very back where the engine bolts to the transmission. The sensor itself is covered by a shield. Get underneath the vehicle, follow the engine back to the transmission and look up. The shield is about 1.5-2" in diameter with the wiring harness coming out of it.
Before i buy this crankshaft sensor is there two fuel pumps located on this vehicle i was wondering about this high pressure fuel pump on the gas line on the motor. I'm not sure if that's what that is but i was wondering if my fuel pump could be pushing gas against this and not coming through it all the time and cutting the pump off. thanks.
