Fuel system problem
95 LR Disco 3.9 hard starting....running weak and not re-starting all the time after running for 15 or 20 minutes.
I hooked up a pressure gauge to it, and when the pump is activated it jumps up to 32 PSI and then drops to nothing ....that's without cranking....
The pump is about 2 years old...
Next steps?
Next steps?
I found my 04 doing similar. I have gone through several pumps thus far and found the issue to be the pressure regulator within the pump assembly which also acts as a one way check valve keeping forward pressure to the fuel rails after the pump is turned off. I decided to install an in-line check valve at the frame rail since I have a leak there anyhow. My current issue stopping me at the moment is the type of fuel line I have on the 04 and what type of connections I need to connect to the line... Just posted on it.
Fuel Pressure Regulator. When vacuum is applied at idle (high vacuum) the regulator diaphragm is opened pulled open to allow fuel to return to tank (less fuel required to idle). Throttle wide open is opposite - regulator diaphragm closed (low vacuum) to allow high fuel pressure (more volume) to injectors. What happens is the FPR does not open or does not close depending on fault. That doesn't explain why the hard starts/no starts when warm problem. Usually the hard starts/warm restarts is due to the coolant temp sensor for the ECU, loss of line pressure or the fuel temp sensor. Can also be blocked fuel filter (canister), pump screen or fuel leakage.
