got a couple codes to address
P1472
P1471 P0606 P0455 just wanted to check, make sure what these codes mean, and order the correct replacement parts, thank you in advance |
Hi there i have an obd2 reader and this is what it said for your codes:i hope it helps:
P1472:Variable inlet manifold motor2: short circuit to ground. P1471:Variable inlet manifold motor1: short circuit to v battery. P0606:ECM / PCM Processor. P0455:Evaporative Emission system leak detected ( gross leak? no flow ) good luck. |
What year and model is your truck, how many miles on it and how is it driving?
its a freelander that doesn't need the intake parts. five bucks says its stalling at times and it needs a throttle body harness repair kit. 606 is the kicker.
