Sponsored by: CARiD
got a couple codes to address
Old May 19, 2011 | 06:25 PM
sabol's Avatar
Default got a couple codes to address
P1472
P1471
P0606
P0455
just wanted to check, make sure what these codes mean, and order the correct replacement parts,
thank you in advance
Old May 22, 2011 | 01:39 AM
pepelebu24's Avatar
8th Gear
Hi there i have an obd2 reader and this is what it said for your codes:i hope it helps:
P1472:Variable inlet manifold motor2: short circuit to ground.
P1471:Variable inlet manifold motor1: short circuit to v battery.
P0606:ECM / PCM Processor.
P0455:Evaporative Emission system leak detected ( gross leak? no flow )
good luck.
Old May 22, 2011 | 08:27 AM
What year and model is your truck, how many miles on it and how is it driving?
Old Jun 1, 2011 | 06:15 AM
Rovin4life's Avatar
its a freelander that doesn't need the intake parts. five bucks says its stalling at times and it needs a throttle body harness repair kit. 606 is the kicker.
04duxlr
Dec 17, 2014 10:34 PM
jaikins
Sep 12, 2014 11:04 PM
94svt50
Jan 14, 2012 01:45 PM
tornado_735
Apr 20, 2009 08:12 AM
CronicJoeBlunt
May 19, 2006 02:21 PM
