Head Gasket Replacement
Milwaukee M12 12-Volt Lithium-Ion Cordless 3/8 in. Ratchet Kit-2457-21 - The Home Depot
that made the job so much easier its not even funny. break the bolt loose and suck it out/ repeat where needed and tighten and re torque.
There's some little things in this DIY route, that you must remember to do , ex 1) - the amount of torque required for tightening the bolts.....2) - the order in which you tighten the bolts.... 3) - being able to check the cylinder surface for total flatness ( what if it needs to be polished ?)... sounds like just a open and close case ,,,,,but its not ........ good luck .
"I'm definitely interested in the DIY route, but what is the skill level? Definitely not a pro" no need to be.
take your time, print out the pages you need from the RAVE. unusual tools you may need 8mm 12 point socket for the valve cover bolts, a 25 inch 1/2 breaker bar, a 5/8 shallow 6 point 1/2 impact socket for the head bolts and a clutch fan wrench, everything else should be in a standard / metric socket set
plan a day to take it apart and clean everything and a day after you get the heads back to install and test.
good luck
good luck
