Sponsored by: CARiD
HEADLIGHTD ON A DEFENDER 110 2002 TD5
Old Jan 14, 2008 | 10:37 AM
GORDON BROWN's Avatar
Default HEADLIGHTD ON A DEFENDER 110 2002 TD5
I HAVE A PROBLEM WITH THE HEADLIGHTS. WHEN YOU SWITCH THE HEADLIGHTS ON THEY DO NOT WORK UNTILL YOU PULL THE DIP SWITCH BACK. THEN THEY WORK AS NORMAL??
Old Jan 15, 2008 | 07:08 AM
Adz's Avatar
Adz
Default RE: HEADLIGHTD ON A DEFENDER 110 2002 TD5
Do you mean they don't work on main beam and you only get sidelights?
Old Jan 15, 2008 | 09:57 AM
Hi.
Thanks for the reply.
When you switch on the headlights the only lights that work are the side lights. To get the headlights to come on I have to pull the dip switch back as if you were going to flash the headlights. Then the headlights will work as normal (main beam and dip beam)[:@].
Old Jan 15, 2008 | 11:46 AM
Sounds like a possible bad head light switch.
leezg
Jul 15, 2014 11:06 PM
Mark Crawford-Thomson
Defender
Oct 11, 2013 07:56 AM
arm52
Jun 17, 2009 04:16 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
rhoadie
Aug 8, 2005 07:15 PM
