help drive shaft pulley reinstall
I am finally getting my truck back together. However, I did not mark the drive shaft where the key is. I put the seal on the drive shaft and notice the slot for the key on the drive shaft pulley. Am I going to have to pull the seal again and mark it? I know about where the key is but of course I can't see it and don't expect to be able to move the pulley once its on there to match it exactly.
Thanks,
Thanks,
"... if there is none under it there ain't none in it *copied this from someone else."
Tow-Mater in Car's 2, said about Miles Axlerod ...an extremely modified version of a Range Rover L322.
If you don't believe it, just ask my grandson.
As for your problem, you should be able to probe for the keyway with a carefully bent piece of stiff but thin wire. Tread lightly... mark it with a sharpie.
"Don't get in a hurry, especially if your getting paid by the hour"
Thanks, I have a mechanic friend who could probably take it in for me and spot weld it but I really didn't want to take it off the shaft again. I have maybe 2mm if that to have it all the way on. I didn't see it on there and I probably did it when I was using a pry bar to hit it. Not much room since I din't take radiator off.
Is there an inspection hole on the trans that you can put something in to lock it up while you turn the bolt on the flywheel? Trying to get the nut back on. I used the starter trick to get it off but having trouble holding it to get it on. Was going to use the nut to get the final 2-3mm I need for the flywheel to be completely back but forgot the wheel turns. Yes, brilliant I know but this is my first real go of it besides regular maintenance. My radiator is on so I can't get a good enough wack at it to get that fully set in.
DiscoJon
07-14-2019 01:51 PM
TripleThreat
04-12-2011 08:58 AM
