HELP Removing a brush guard
HELP - I just removed the factory installed brush guard from my 2004 RR HSE. It is definitely the factory brush guard, i assume a dealer installed it. After i removed the brush guard there are 2 holes in the bumper where the 4 bolts held the guard to the bumper. How to i fill or hide those holes? It looks like the installed cut into the bumper a little when installing it? The parking sensors go back in the there original holes after guard is removed.
Just tying to figure out how to fill or cover the bolt holes, 2 holes in bumper?
Did same thing with a 2003 HSE hated look with brush guard. New or used front bumper cover is only good solution. Bodyshop can try to plastic weld the holes then sand out but chances are you will still see. Bought my bumper from junkyard in Texas $225 including ship. Good luck
smokinwheels
05-25-2021 11:11 PM
christiansmith6
01-07-2014 07:46 AM
SpeedAgent
03-16-2008 11:06 PM
DiscoMikeandMike
12-17-2007 01:37 PM
