help runnung lean
help runnung lean
i have a dicso II 2002 i ran the codes and it is running lean. bank 2 sensor 1.
there where a few more codes that popped up also saying the system was lean. where is a good place for me to start looking for a fix?
also i don't have the tools to check fuel presser and what not. I'm all wrenches.
thanks for the help
thanks for the help
I had the similar problem with my 04 RR-HSE. In my vehicles case, it turned out to be the Air-Massflow Sensor and Vacuum Hose that connects to it. At first we thought it may be the oxygen sensors, so I replaced those; but the code kept popping up, so upon replacing those parts I previously mentioned on top, it fixed the problem. Good luck man. Keep on Rovin...
cobralootman
12-05-2006 02:38 AM
hoberock
07-18-2006 10:24 PM
