Help with secondary air
trying to remove the heads on an 04 D2. Can’t get the damn secondary air injectors off. If I try to loosen the metal lines, the whole connector just turns. I’ve tried everything I can think of. Anyone have this issue before? |
Use an 18mm crows foot to hold the block side bolt while you remove outside nut. |
Once you unbolt the exhaust manifolds (both sides) and let them drop out of the way...you can easily get a 18mm wrench in there to hold the head fitting. Sometimes, a small amount of heat helps too.
Brian. |
