Sponsored by: CARiD
Help with secondary air
Old Dec 2, 2018 | 03:01 PM
Alexrover's Avatar
Default Help with secondary air
trying to remove the heads on an 04 D2. Can’t get the damn secondary air injectors off. If I try to loosen the metal lines, the whole connector just turns. I’ve tried everything I can think of. Anyone have this issue before?
Old Dec 2, 2018 | 03:10 PM
Frtpilot's Avatar
Use an 18mm crows foot to hold the block side bolt while you remove outside nut.
Old Dec 3, 2018 | 06:40 PM
The Deputy's Avatar
Once you unbolt the exhaust manifolds (both sides) and let them drop out of the way...you can easily get a 18mm wrench in there to hold the head fitting. Sometimes, a small amount of heat helps too.
​​​​​​​ Brian.
DiscoBuckeye
Oct 11, 2018 08:52 AM
ajh
Sep 12, 2011 09:28 PM
haleyrover
Jun 23, 2011 07:52 PM
04BluDisco
Dec 1, 2008 10:10 AM
alphawolfman
Nov 16, 2008 07:57 PM
