Sponsored by: CARiD
high idle,running rich
Old Sep 17, 2006 | 05:04 PM
disco boy's Avatar
7th Gear
Default high idle,running rich
i have a98 disco LE. i filled it up one day next thing i know the idle was running super high,,thought it was the gas maybe,,,,but several full tanks later still high and also running very rich. The idle does seem to drop down once it warms up. Con someone PLEASE tell where to adjust the idle i can't find the d*mn thing. PEACE
Old Sep 17, 2006 | 07:05 PM
Default RE: high idle,running rich
You don't want to try and adjust the idle down, you need to find out what is causing it to happen.
Do you have a check engine light?
Can you pull the idle down by pulling the throttle cable or hand rotating the throttle body?
Mike
Old Sep 18, 2006 | 12:20 AM
disco boy's Avatar
7th Gear
No check engine light.... and no for the other two. Have any other suggestions??
Old Sep 18, 2006 | 10:30 AM
Sounds like your idle stepper motor must be hung up, trouble is, I don't know where it is located on a 98 D1. You might ask around as to where it is and tray and clean it out with carb cleaner.
That's the only thing I can think of.
Mike
wick_60010
Nov 22, 2017 04:25 AM
rick williams
Nov 29, 2013 08:10 PM
vpadferg
Jan 19, 2013 09:41 PM
dmonares
Aug 27, 2006 01:47 PM
Tibbs
Oct 2, 2005 12:08 AM
