How to Change the Oil Pump...
Old 02-20-2009, 04:03 PM
Mtree's Avatar
Default How to Change the Oil Pump...
Hello All,
I have been searching throughout the site and haven't found a write-up on how to change the oil pump on the 2003/2004 discoveries.
Can anyone direct me in the right direction so i can look it over???
Thanks!!
Old 02-20-2009, 04:35 PM
Why do you want to change it??
Old 02-20-2009, 05:12 PM
Mtree's Avatar
I would like to know what this job entails to see if this is something i can do myself. Just doing some research...
Old 02-20-2009, 05:16 PM
Do you have an 03 that is on Rover vin list of possible engine failures?
How mechanical are you?
Old 02-20-2009, 05:24 PM
Mtree's Avatar
I'm currently in the market. Test drove a few and pretty much have made up my mind on a 2004 model Discovery. I seek the info because i have also read that a few members here have experienced issues with faulty pumps in thier 2004 DII. I would just like to eliminate any doubt on the PO ability to maintain a vehicle and change the pump.
As for mechanical inclination, i majored in ME but went to IE for the easy $$ or else i would've stayed. One thing holding me back would be special need tools...
Old 02-20-2009, 06:46 PM
The 03 issue has not carried over to the 04 with the exception of normal oil pumps failing based on a weird set of stats.
If you are going to get to **** over this purchase, back off and look in other areas of the market so you will be able to sleep well.
Old 02-21-2009, 12:18 PM
Mtree's Avatar
I understand the situation has not carried over to the 04' models I'm well aware of the TSB and all trucks affected. I just wanted to read the write-up.
Ok, With that being clear where can i find the info on how to change the oil pumps on the 4.0L Disco II.
Old 02-21-2009, 08:35 PM
I really don't see where you are coming from with this question? Why are you worrying about something that will never need to be done?
Go down load a Rave CD.
Old 02-22-2009, 01:12 PM
Mtree's Avatar
Ahh! Thanks Disco Mike!! I'm getting excited for my new purchase!!!
Test drove a 04' HSE7, just waiting on the dealer to get back to me on some history reports..
Old 02-22-2009, 02:01 PM
How much are they asking for it, remember the prices are really dropping.
Quick Reply: How to Change the Oil Pump...
