Leaking Brake Fluid 1990 RRC
Hey all,
I have a 1990 Range Rover Classic which is leaking brake fluid from behind the driver's side wheel just about under the drivers side door.
When parked a smallish puddle forms (nothing huge or gushing). I refill the reservoir and the brake light goes off for about a day but then comes back on again as the level drops. Brake function still seems fine.
Can anyone offer me a troubleshooting guide to identify where the leak is coming from and then how to address it?
Thanks!
Thanks!
check around the union in the wheel well as the line starts to follow the frame. Likely that the lines are starting to rot through. I'm surprised that you're not seeing any drop in braking performance though... if you're loosing that much fluid, you should be sucking in air every time you release the pedal, making your brakes feel soft.
NebsRover'90
04-18-2011 09:28 PM
NebsRover'90
04-07-2011 10:02 AM
drhodes
10-02-2009 12:31 PM
