Lockdown
Sounds like you might have gotten your ECU wet, DI's are a little more sensitive to water than DII's, especially with the undercarriage wash......Park it in the sun and let everything dry out and see if anything changes.
I'm sure someone else will chime in that has had a similar experience, you are by no means the first...
Not sure if it's drive-able, but if you can get it to an auto-parts store they can read the codes for you and tell you what the computer is saying is wrong. Post the codes they find in the Discovery I section and you'll get some good answers and troubleshooting tips.
