Sponsored by: CARiD
Low-range won't engage
Old Jan 22, 2009 | 12:30 AM
landy@oz's Avatar
4th Gear
Default Low-range won't engage
Low-range won't engage. When lying under vehicle you can hear it change in transfer box but the low range selector lever going from the transfer box to the front diff doesn't move. Can this be fixed through taking off the transfer box panel and lying under the car? 1998 Landrover Discovery TDI manual.Thanks.
Old Jan 22, 2009 | 01:34 PM
Default RE: Low-range won't engage
You can have either the switch in the tranny or the solenoid in the t/case fail and you won't be able to shift it.
Old Jan 22, 2009 | 03:19 PM
landy@oz's Avatar
4th Gear
Hi Disco Mike, RE: low range problem, is this a problem I can fix at home, (easily repaired), or are special tools needed and best left to the experts. Thanks. Oh and thanks for your advice ages ago on my problem with the rear electric windows not working, you saved me $$$. Thanks again John.
Old Jan 22, 2009 | 04:01 PM
bonnettoboot's Avatar
I think this is the wrong forum for Discovery! But what linkage are you referring to, nothing goes to the differential!It is all inside thetransfer box, the linkage to the drive train lock up is now disconnecteddue to ABS traction control issues.
________
MB5
Old Jan 23, 2009 | 06:06 PM
You has either a bad tranny switch ot a bad t/case solenoid.
OZ,
I have seen where some have fixed this problem, can't say I would recommend it. PM me with your tele number, I'll call you tomorrow.
bballjames
Apr 1, 2014 09:55 PM
jmason
Sep 28, 2013 03:26 PM
jdogg
Jan 28, 2013 10:00 PM
swissfan
Jul 13, 2010 11:43 AM
GreenRover
Jun 25, 2008 04:18 PM
