Sponsored by: CARiD
Master cylinder froze
Old Nov 11, 2012 | 03:44 PM
Chapman Conti's Avatar
Exclamation Master cylinder froze
I noticed i was leaking brake fluid from below brake res, I searched for just the rubber inserts but no luck.. I picked up a new master cyl, bench bleed the cyl.
installed it in the rig, bleed all four wheels. Now I had good fluid coming out , had a nice firm pedal so I took her for a test drive all was good for bout a mile then all four wheels locked up.. The break pedal was rock hard no movement at all.. No leaks anywhere. To get it home I cracked the lines off of the master cyl, no pressure build up, fluid just leaked out... Stuck no clue now.
Bleed sys as per Rave man..
97 Disco I.. all new brakes, calipers, rotors,
Need any advice.. any where else that should be bleed??
Thanks Chapman
Old Nov 11, 2012 | 03:50 PM
You bought a non original Land Rover master cylinder, you cant do that.
For some odd reason after market ones never work on the DI, this happens each and every time.
You need to bite the bullet and buy a Land Rover master cylinder.
Old Nov 11, 2012 | 04:22 PM
So Im screwed till I get new one from atlantic british.. No way to make this one work? price not issue, just time was crunched and location at the time... it works for a bit then wam..
Why or what causes them to not operate rite
Old Nov 11, 2012 | 05:36 PM
If you can adjust it you can make it work.
How you adjust it I dont know.
If you need it to get to work tomorrow I cant be of much help, sorry.
Old Nov 12, 2012 | 05:37 AM
Thanks Spike, I found a donor rover with 54,394 on it with wrecked front end.. brakes felt good on it.. I swapped out it master and so far no problems... I'm waiting for new one to come in... again thanks for the advice...
Chapman
Old Nov 12, 2012 | 08:31 PM
No prob and good luck.
geek_IM
Aug 5, 2010 09:41 PM
tibyABv6
Jun 21, 2009 06:12 AM
Phototone
Nov 13, 2008 07:54 PM
TVO
Mar 15, 2007 12:08 PM
leebuhrul
Feb 26, 2006 03:38 AM
