Misfire Catalyst fault codes
I have a 1999 Discovery SD, a flashing check engine light came on, its sending codes :
1313 - Misfire Catalyst Damage Fault Bank A
1314 - Misfire Catalyst Damage Fault Bank B
1374 - Early Ignition Coil Activation Fault Coil 4
Cleared codes..they came right back...I replaced the MAF, plugs and wires, engine seems to run and drive ok.
Can anyone help with what the cause of these.
