new owner and have a a few questions...
just aquired a 01 land rover SD with 12,200 miles, yea thats not a accident, 12k, and was wondering what it has for front and rear diffs. i am an off road guy buut havent touched anything more than Jeeps and Fjs for hard wheeling. this most likely wont be a wheeler but i was wondering if it has open diffs or limited slip diffs?
RE: new owner and have a a few questions...
It has open diffs.
But if you have a early 01 I think you may have a locking transfer case that would need a after market cable to work. |
The diff assemblies are made by Rover, are you planning to go to lockers, if so you will need to see if your truck has a locking t/case.
E-mail me and I'll send a picture of what you need to look for. 12,000 miles, that is great. Don't forget you will, even though the mileage is low, want to change out some fluids. |
all the tboxes are locking you just need to make a linkage to lock the case, ive done several and just made a simple shifter with a cable, through the trim of the bottom of the drivers seat, you pull it to lock the diffs
ORIGINAL: wardolb all the tboxes are locking you just need to make a linkage to lock the case, ive done several and just made a simple shifter with a cable, through the trim of the bottom of the drivers seat, you pull it to lock the diffs |
