Newbie 01 disco won't start not getting spark or gas
Hi new to the forums any help would be greatly appreciated! The disco had been sitting for around 6 months not started or anything, went to jump start it two days ago and it started right up! Then moved it parked it to run in house and grab something and it's not running I'm not sure if I turned off or it died! Went to jump again and it just cranks. It's not getting fuel can't hear fuel pump and it's not getting spark. Lights work, Windows work. Get codes P1842, P1843, Read something about ecu not communicating with another part, but of course can't find that again!
When you say you try it, I assume this not starting.
A crankshaft sensor only provides crankshaft position info to the Engine computer.
Why do you think you have no fuel? Did you check the fuel pressure?
A engine needs the air, fuel and spark to run. If you don't have spark, fix this first. You can always add fuel with carb cleaner into the intake for testing. You can also remove the spark plugs after cranking and smell them for fuel.
It just cranks. Won't turn over. Sprayed starting fluid into air cleaner it started for a min but sputtered out. I took fuel line apart right after the tank and had someone turn key and didn't spray fuel or anything. Put screwdriver in a wire and placed against metal and no spark.
Thank you
