No overdrive!
No overdrive!
So, I fixed my cooling system which necessitated removing the radiator and now my tranny won't go into overdrive. Trans fluid was a little low, but it still won't shift. It was working fine before the repair. Am I missing some special Land Rover-only step? This is frustrating and any help would be very appreciated. Thanks.
This makes no sense, it was fine before, now its not.
I need to think about this for a few.
Have you tried shifting into neutral and then trying to drive?
Maybe the shift linkage got moved and you are actually in 3rd gear and not in 4th on the gear selector?
To clear a few things up, there is no XYZ switch on a DI, totally mechanical transmission.
There is no gear indicator on the dash of a DI either.
Yes, Spike, I actually cycled through all the gear positions. No effect. Cable was already eliminated as a possibility. We're thinking that fluid may still be the culprit. My brother is going through it again tomorrow. Thanks for the suggestions, guys. I'll get back to you guys with the update asap.
