OBD II Diagnostic tool
I’m new here. Just purchased a 2001 Land Rover Discovery II. The forums have been so helpful. I was curious if anyone can recommend a diagnostic tool to use? The one I have provides very limited info. I wondered what folks were using?
Secondly, I have the 3 amigo lights on and have been trying to narrow down the culprit or culprits. My transfer case is stuck in High. I’ve read that this could mean I need to replace the shuttle valve (which could also be causing the issue with the 3 amigo lights). Has anyone replaced this from underneath the vehicle instead of down through the center console? Any advice is greatly appreciated.
Hello, I have also purchased a 2001 Land Rover Discovery II and I also want to know which diagnostic tool I should use and I am glad I found your post where I found my problem solution. I also found https://www.topwritersreview.com/blo...are-important/ website in which I found a blog on how to cite a source and why citations are important. And thanks to you for sharing diagnostic tool information with us.
I’m new here. Just purchased a 2001 Land Rover Discovery II. The forums have been so helpful. I was curious if anyone can recommend a diagnostic tool to use? The one I have provides very limited info. I wondered what folks were using? Speed Test
