oil transmission light indicator
Good day guys, for sometimes now my oil transmission light always come on whenever I am held in traffic when the engine is still on and it will goes off at times when I drive on and stay on at times too. Any help will be highly appreciated, thanks in advance.
if 15
that is a temp light operated from 2 senders. one is on the transfer case and the other is on the trans oil cooler (right side) sensors can go bad, but 1st thing 1st check the level of fluids.
an easy way to determine which is your trigger......next time its on, crawl under and pull the 2 leads off the tcase sender. if the light goes out, that one is yo problem
Thanks guys, I was talking about transmission temperature warning lamp (red). I am sure the fluid level is ok as I was forced to completely replaced it when it started so it can not be the fluid. So Dusty 1, what are the two leads were you talking above and what is the tcase as well? Pictures will really help. Thanks in a million
