Overheating
Overheating
I have a 2001 Disco II and my temp guage when red the other day and i drove it back home. only about 2 miles back. When i got home i opened the hood and there was steam coming out from behind the engine. I think something busted and it was leaking all on the engine. It leaked alot, does anyone know what exact part i need to replace cause i can't see the hose back there.
RE: Overheating
Yea i called my local land rover guy. he says its most likely the heater hose. i loaded it with water(cause it leaks slower than coolant) and 3 jugs of water. I was able to get it to the shop (15 miles) with out the temp gauge moving higher than half way. he is going to look it over first thing tomorrow morning and fix it if it is the heater hose. All for free.
on
RE: Overheating
Steve, unless the heater is dripping on the carpet,it won't be the heater core. Does your mechanic have any Rover experience?
You might want to send me you tele number so we can talk cause I think you are looking in the wrong direction.
Mike
mikeljcacob@comcast.net
Mike
RE: Overheating
ok i talked to my guy and he says that he never saw a leak. He let it run, he drove it around and brought it back. He said he will let it run and park it inside his shop and leave it over night. The pressure should show where the leak is or if there is a leak at all. well i know there is a leak cause it was all over my driveway.
