Sponsored by: CARiD
p38 window regulator/motor
Old Aug 5, 2007 | 03:41 PM
darrenh1975's Avatar
4th Gear
Default p38 window regulator/motor
Hi guys i'm new to this forum so hello to everybody.
I have a 1999 p38 range rover last month the drivers door window regulator started making horrible noises and the window wasnt closing properly and window not set was showing on the dash. I took the door card off and the last 4 teeth of the regulator had been worn/stripped away so I got a new one.After fitting it all has been good until this evening when it made the dreaded noise again and window not set came up again.So once again I took the door card off and to my horror the same 4 teeth have been stripped again.I know that the regulator should last more than a month so what could be causing the problem here could it be the actual cog on the motor thats worn and wearing the teeth on the regulator any help you can give will be great ,I am going to call the supplier that I got the regulator from in the morning to see what they have to say. Please help me before I get shares in qhoever makes regulators.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
pelias
Jul 14, 2008 10:08 AM
zachbraff
Jul 18, 2005 12:57 AM
