mylemon |
10-13-2009 10:53 AM |
Please Help 04 land rover discovery DEAD!!!
2004 Discovery I was driving home, the engine sputtered once the engine light flashed so fast i could hardly see it... 5 miles down the road it quit running engine light and transmissions light both gear lights and D light on the shifter flashed, after 15 minutes it restarted. but would not shift right, actually would not shift out at all.. i had to get it home drove it another 20 minutes and it quit again.. after about and hour it restarted.. made it home where it died again..i have put a new battery in it(dealer recommended this) It has no engine fire! I thought with the transmission and all it was probably the ECU, Changed it, this did not help,, I put the original ecu back in it,,, Wow you know i thought about this but figured i was wrong THE COIL PACK/electronic ignition.:confused::confused::confused: Could this be it??? Will i have to take off the intake to get to it???? would you have any hints ,,,,
