Sponsored by: CARiD
Power Steering noise when cold!!
Old Dec 11, 2009 | 12:04 AM
Testpilotb's Avatar
7th Gear
Default Power Steering noise when cold!!
Hey all thanks for all the help in the past and for a great resource.
I have a 2000 disco 2 with 126K on it. I replaced the PS pump and all of the hoses in October because a hose went and killed the pump. It has been working well but in the past week the temps have dipped to slightly below zero here in UT. When I first start the truck in the AM it screeches pretty loud and it sounds like the P/S pump. It goes away in about 5 to 10 seconds...should I be worried about killing another pump? I didnt use a synthetic fluid when I replaced the pump, but I did use some of the lucas adative.
What can I do to keep everything running? the PS pump job wasnt too bad but isnt something I want to tackle again 3 months later.
Thanks in advance!!
Dave
Old Dec 11, 2009 | 09:05 AM
Is it a new pump and how much Lucas did you use?
Old Dec 11, 2009 | 09:10 AM
Testpilotb's Avatar
7th Gear
Mike,
Yes pump is new not remanufactured. I got it from Atlantic British. I used about a half a cup of lucas. I know its thick so I didnt want to use too much.
Pump is quiet after it warms up, I just wonder if I should use some fluid that isnt as viscous when cold?
Old Dec 14, 2009 | 11:16 AM
Testpilotb's Avatar
7th Gear
Started it this morning when it was 35 degrees F and the P/S pump didnt make a sound....I put prestone PS fluid in it when I first replaced the system. I am assuming that its the cold weather that made the pump whine. Does the Land Rover brand PS fluid work better when its that cold out? Thanks again
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
jrkstore43
Jan 8, 2012 09:31 AM
orionpaxx
Nov 7, 2011 10:07 PM
Robbo
Jun 15, 2005 05:03 AM
